Switched to solid, no change
Forum Archive Switched to solid, no change
  • #6946
    Sid Lilja
      Hi, following your video the mesh in viewport renderer should’ve changed appearance when choosing Solid, but did not do so for me. Using Blender 2.79
      #26234
      Julian B
        You need to disable “shadeless” which should still be turned on (press N/ Shading/ Shadeless).
      • The topic ‘Switched to solid, no change’ is closed to new replies.
