Question:
(Can’t add images, there is a bug on this website. It’s strange. 🙁
Subdivision surface disabled in render (12)
Error message: ”Autosmooth or custom normal detected, disabling GPU subdivision.”
I added a modifier, to The mesh ”pot”, datatransfer, to fix the normals so it can have a perfect shading. The source of the datatransfer is pot_normal. Pot_normal is a copy of the mesh pot, that I divided in two, to keep the perfect round shape that has perfect shadings.
I ”copied to new driver” the levels viewport and render in subdivision surface options from pot to pot_normal, which is both ”4”.
I had to check the box: autosmooth, in order to make the datatransfer to work. But when I do so, the error message above appears, and subdivision surface cannot be applied in render mode (12).
Pointless Solution:
I have to either uncheck both autosmooth or delete the mesh pot_normal. But this is pointless since the idea is to make a datatransfer.
The question is why do I get that error message? Thank you.
