streaks on mesh?
Forum Archive streaks on mesh?
  • #19598
    Kai VDL
      So when i was filling on the faces for the speakers in the Press start tutorial, these streaks appeared on my mesh and im not sure why. I was wondering if anyone knew why.
      #92823
        Looks like overlapping faces? Try selecting it in face select mode and delete it so you can fill the gap anew. Also try the other usual suspects, merge vertices by distance, see if you have flipped normals and recalculate them with Shift + N.
        #92824
          And while you’re at it, please Apply the Scale (in Object Mode, CTRL+A > Apply  > Scale). You’re going to need to adjust the Amount in the Bevel Modifier then, because a 12mm Bevel on a less than 3mm thick model is a bit much😉
          Let us know if Omar’s suggestions worked.
        • The topic ‘streaks on mesh?’ is closed to new replies.
