My guess would be that maybe you had 2 material slots with the speakers assigned to the 2nd but with a default material or no assigned material (which will usually give a default material look until one is assigned to the slot). Glad you solved the problem on your own, though keep in mind, adding some images showing the problem (including what your material settings are in this case) would help us to help you better 😀
