Source Object position
Forum Archive Source Object position
  • #7946
    Ivan Makarov
      Hello Thibaut,
      Your tutorial was right in time and helped me a lot. Thank you. The only one addition is the Source Object must be in the same position as the target when using the Data Transfer Modifier.  Took me some time to understand that.
      #27908
      Thibaut Bourbon
        Good call, thanks for pointing that out! Indeed I should have explicitly mentioned it in the tutorial: so the key is to duplicate your initial object before applying any boolean operation and either hide it or move it to another layer. You can also parent the source object to the one you’re modifying so that they always keep the same position  if you plan to move things around.
        /Thibaut.
      • The topic ‘Source Object position’ is closed to new replies.
