[SOLVED] One face appears darker
Forum Archive [SOLVED] One face appears darker
  • #12642
    Ingrid Frank
      The face looks darker in viewport shading and when rendered.
      So far I checked the normals, deleted the face and filledit again and unwrapped the mesh again
      Does anyone have an idea what´s going on?
      #59982
      Jonathan Lampel
        Hmm, it looks like it’s just unwrapped differently because it doesn’t have that bottom and top lighter edge. What do the UV’s look like for that area?
        #59983
        Ingrid Frank
          The lighter edges are because of the seams which I added with another UV map.
          Seams
          UV for the whole thing
          I also tried to pack the islands and scale the texture with a mapping node instead of scaling the islands, but the same issue occurs
          #59984
          Ingrid Frank
            I was able to solve the issue.
            Rotating the UV of the face for 90° fixed it
          • The topic ‘[SOLVED] One face appears darker’ is closed to new replies.
