Solidify causing artifacts
Forum Archive Solidify causing artifacts
  • #17685
    Zoltan Fodor
      Hi guys,
      I’m modeling a car and run into a weird problem, the solidify modifier causing artifacts.
      I searched for solutions, checked if there are overlapping vertexes, normals facing the wrong way, all seems good but the problem still there.
      I’ve attached a blender file here if that helps finding out what am I missing:
      https://we.tl/t-ceiXCAkddb
      Any help would be much appreciated, thanks in advance.
      #84871
        Hi Zoltan,
        You can reduce the shading artefacts, but switching to Complex and maybe Add some more Edge Loops:
        But better results are to be had, by Shrinkwrapping the Mesh to a higher resolution ‘helper’ Mesh, that has the same shape, but without the holes.
        #84872
          You can watch the Pothead course where JL models the pot and head to see how a guide or helper mesh helps with that:
          https://cgcookie.com/lessons/modeling-the-pot
          #84873
          Zoltan Fodor
            Thank you both, I ended up creating depth by adding geometry and an extra edge, so it’s sharp enough.
          • The topic ‘Solidify causing artifacts’ is closed to new replies.
