solid fill assign not working, just strokes colour change not fill.
Forum Archive solid fill assign not working, just strokes colour change not fill.
  • #21709
    parham sh
      #100869
      Grady Pruitt
        If you’re using a 5.x version of Blender, they recently changed how strokes/fills work. If you go to edit mode, select the strokes you want to be fill, then under Stroke -> Set Stroke Type, you can chose stroke, fill, or both.  In 5.2, there’s a set of buttons between Strength and the end cap buttons where you can set this in draw mode for the next stroke you want to do.
      • The topic ‘solid fill assign not working, just strokes colour change not fill.’ is closed to new replies.
