Smoke particles not showing up in either Rendered Image or Animation.
Forum Archive Smoke particles not showing up in either Rendered Image or Animation.
  • #10799
    stoneocean
      At no point do the particle show up during rendering time. They are however checked to to be rendered.
      #51232
      Jonathan Lampel
        Hey @stoneocean , in your scene do you have the Smoke Particle object assigned as what the particle system should render in the particle properties Render panel?
        #51233
        stoneocean
          Nevermind I found it! It was the Smoke Emitter that was disable for render.
          Thanks for the help tho.
        • The topic ‘Smoke particles not showing up in either Rendered Image or Animation.’ is closed to new replies.
