Slow Cycles viewport
Forum Archive Slow Cycles viewport
  • #13528
    cgmurilo
      When I work with cycles directly from the rendered viewport it gets kinda slow because my computer is not very powerful. I understand that won’t matter too much if I just wait a bit longer for it to render or minimize it’s use. I’d like to know if there’s anything that could be done to imporove the sampling speed a bit?
      #63045
      Jonathan Lampel
        You may want to try using Ctrl+B to preview a small area at a time rather than the whole screen. Also, if you have denoising on, set the start sample to whatever you have  the viewport sample count at. Lastly, head down to the Performance > Viewport options and increase the Pixel Size.
        Hope that helps!
        #63046
        cgmurilo
          Thank you, It helped me a lot!
        • The topic ‘Slow Cycles viewport’ is closed to new replies.
