Slider axis
Forum Archive Slider axis
  • #18642
    Hugo Falarz
      Hello,
      the Slider work only in X axis, but if the object in our scene need to move along the Y axis for example, how do you proceed ?
      #89003
      Hugo Falarz
        Nevermind i think i found the answer, i used an empty and it worked 🙂
        #89004
          Hi Hugo,
          That X-Axis is the Object’s (Local) X-Axis, so you could also, for instance, use the Options > Transforms > Affect Only > Origins and Rotate the Objects Origin so, that its X-Axis is pointing in the direction you want to Slide it in:
          Hard to visualize this in one picture…hope it is still clear.
          #89005
          Hugo Falarz
            Oh yes, it’s easier this way thank you !
          • The topic ‘Slider axis’ is closed to new replies.
