Skinning Piero’s Mesh: Duerer’s Progress:
Forum Archive Skinning Piero’s Mesh: Duerer’s Progress:
  • #13070
    Ingmar Franz
      A posing test for Piero after parenting the mesh to the “Deformation Bones” using “Automated Weights”:
      #61503
      Ingmar Franz
        A Cycles test rendering with the feather meshes skinned:
        #61504
        Ingmar Franz
          All feather meshes skinned to their corresponding bones:
          #61505
          Ingmar Franz
            There’re gaps opening when the claws are clutching:
            Also with the original Piero:
            The toe nails probably shouldn’t rotate so freely.  I tried lowering the vertex weights for the nails but this didn’t change the behaviour.
            #61506
            Ingmar Franz
              With some corrections to the toe nails, the gaps shouldn’t be visible as long as no close-up views are needed:
              #61507
              Ingmar Franz
                I’ve reshaped the toe nails so that they now better close the gaps:
                #61508
                Shawn Blanch
                  Wow it is really coming together. Nice work @duerer
                  #61509
                  Ingmar Franz
                    Thank you, @blanchsb 😀! Some weight painting still has to be done in the head and shoulder area 🎨.
                    #61510
                    Ingmar Franz
                      Piero’s main rig is now complete:
                      The Cycles rendering is here.
                      Next step: Facial shapekeys and their rig.
                    • The topic ‘Skinning Piero’s Mesh: Duerer’s Progress:’ is closed to new replies.
