Simple Glass with new BSDF
Forum Archive Simple Glass with new BSDF
  • #17321
    Nathi Tappan
      With the moving around and renaming, where would I find the transmission roughness if I were to emulate this very simple glass material using the BSDF?
      I think I’d switch to the more complex material that we learn on the next lesson for a final render, but for quick materials this doesn’t look half bad.
      #83334
      Nathi Tappan
        Do I see it correctly, that I can just increase the weight of transmission to 1 and call it the day? I
        #83335
        Dwayne Savage
          I’m assuming you mean the Principle BSDF in Blender 4.0. It’s no longer 2 separate inputs. The roughness input is used for both diffuse and transmission roughness. Setting the transmission weight to 1 activates the clear(Glass) material. You will want to adjust the IOR too. Glasses are usually between 1.5-1.53. Windows are usually 1.51-1.52. I use 1.503 for windows and 1.523 for cups.
          #83336
          Nathi Tappan
            Awesome! Thank you Dwayne!
            #83337
              Indeed, the Transmission Roughness has been removed in the new Principled BSDF.
              This means, that you no longer directly can make a ‘milky’ glass with clear reflections, but in 99,9% of the cases, you won’t need that and it is easier to just have one roughness to take care of…
              #83338
              Nathi Tappan
                That makes sense! It’s pretty handy to get it working so quickly… we can always pull out the separate shaders if we need 🙂
              • The topic ‘Simple Glass with new BSDF’ is closed to new replies.
