Silly but I am stuck right after extruding – how to initiate the scaling?
Forum Archive Silly but I am stuck right after extruding – how to initiate the scaling?
  • #11748
    Marcelo Eduardo
      Using a Mac with an external mouse…
      #55916
      ogonzales
        It will appear as if nothing has happened, but with the extruded surface (facer, edge, or point) press g (to grab) then z and move your mouse in the Z direction.
        #55917
        Ido Reshef
          Did you try to press ‘S’ right after (and then move your mouse) ?
          #55918
          kyothecat
            Editing my answer cause what I thought was a solution wasn’t at all 🙁 It was easier to start all over because I deselected during the extruding step and it made it complicated because to fix it you’d have to reselect all the vertices.
          • The topic ‘Silly but I am stuck right after extruding – how to initiate the scaling?’ is closed to new replies.
