Should modifiers be added in "Edit Mode" or "Object mode"? I realize while practicing that it is available on both of them.
Forum Archive Should modifiers be added in "Edit Mode" or "Object mode"? I realize while practicing that it is available on both of them.
  • #5477
    sebfct
      Should modifiers be added in “Edit Mode” or “Object mode”? I realize while practicing that it is available on both of them.
      #23933
      Stanley Leland
        Modifiers only work in object mode.
        #23934
        Stanley Leland
          Here is a little more detail on this.
          Modifiers can only be applied to objects, not to parts of objects that you may have selected in edit mode. In other words modifiers can only be applied in object mode (it’s possible to ‘add’ them in edit mode, but not to finalise or ‘apply’ them there).
          #23935
          sebfct
            Thank you for the answer! So from what I understand it works only in object mode, that’s means it doesn’t matter wether I create my modifier from the object mode or edit mode?
            In the following link I am creating a mirror modifier in edit mode: http://img11.hostingpics.net/pics/148511temp.png
            #23936
            sebfct
              Ok, thank you very much @wanderingmonk7. I got it from your detailed answer.
            • The topic ‘Should modifiers be added in "Edit Mode" or "Object mode"? I realize while practicing that it is available on both of them.’ is closed to new replies.
