Should I do this for a young person (likeness)?
Forum Archive Should I do this for a young person (likeness)?
  • #15120
    fearguyq
      Is doing this step more or less important for a face that has few, if any, wrinkles in order to achieve that highest level of detail for expressions? Since I would have to predict where to put bevels for crows feet, eye trough, brow, etc. deformations, I was curious if it still made sense to do this to achieve that highest level of deformation detail.
      Model for reference:
      #74268
      fearguyq
          This step is really only important if you plan to rig + animate your portrait. If that’s not your plan, then this concept and video can be ignored.
          But in the case of rigging + animation, even young faces have high potential for wrinkles when deformed (even when no wrinkles are present in a neutral state). Chris Jone’s incredible example showcases this:
          So for highest  fidelity facial deformation, it’s wise to consider key wrinkles being compensated for in the retopologized base mesh. Here’s another example showing a [young] character in Avatar and how wrinkles potential is built into the base mesh:
          #74270
          fearguyq
            I do plan to rig the portrait for use in many still renders with varying emotional contexts. Then though, I imagine I can just tweak anything I want after setting up the proper expression with the rig for each still?
          • The topic ‘Should I do this for a young person (likeness)?’ is closed to new replies.
