I’ve got an object I’m exporting to Substance Painter and I have UV unwrapped it with a subsurface modifier on the model. All looks good in Blender and in Substance Painter until I apply a texture in Substance Painter and then I get strange artifacts where the subsurface is causing the most alterations to geometry.
I’ve tried using a triangulate modifier in combination with the subsurf modifier, but that didn’t help.
The only thing that helped was applying the subsurf modifier before UV unwrapping. Is this the correct workflow to have to do this?
