Shift-CTRL-C?
Forum Archive Shift-CTRL-C?
  • #19421
    Grady Pruitt
      Did they change something with 4.3, because when i try the “Shift-CTRL-C”, nothing happens.
      #92204
        HI Grady,
        That shortcut hasn’t changed in 4.3.
        Make sure that you are in Pose Mode.
        And use the Blender Version from the Course (4.2), if you want to avoid confusion.
        #92205
          And of course, make sure you don’t have a pesky addon that is doing something fishy. Sometimes those addons can be the jokesters of the Blender world, the jesters, the king’s buffoons. I got it, The Blefoons.
          #92206
          Grady Pruitt
            When I press F3, I can find it, and it does show the same shortcut, but for some reason, when I press those keys, nothing happens.
            #92207
            Grady Pruitt
              even tried pulling it up in 4.2 and turned off all the add-ons, and still wasn’t doing anything when I press the shortcut… but did work through the Pose menu or if I used F3 to find
              #92208
                You have to be in Pose Mode for it to pop up, it’s the only mode it will show up in.
                #92209
                Dwayne Savage
                  Ctrl+comma or Press F4->Preferences or click Edit menu->Preferences. Then in bottom left corner click the 3 bar icon->Load Factory Preferences. If you have a Save Preferences button you will need to click that after loading factory; otherwise, you will have the problem again when you reload blender.
                  #92210
                  Wayne Dixon
                    Hi Grady,
                    I can recall something recently where someone’s operating system was taking control of some of the hotkeys.
                    This meant that everything was correct in the Blender settings (ie – they are default and that hotkey is unchanged)
                    However, their computer wouldn’t register that combination being pressed.
                    I can’t recall if it was this hotkey combo or not, though.  I did have a look around in my notifications to see if I could find where that was, but I do get quite a lot of those.
                    Can anyone else remember a conversation similar to this recently?
                    If the factory settings are still having issues for Grady, it’s possibly the operating system is stealing those keys.
                    #92211
                      Good point Wayne!
                      I remember having some issues, mostly with the ALT key, but also the CTRL+F12 (which did something silly like ‘show desktop’ or so).
                      If that’s the case, you’ll need to change them either in the OS or in Blender.
                    • The topic ‘Shift-CTRL-C?’ is closed to new replies.
