Shift + 7: Rotate Viewport to Normals flipping upside down
Forum Archive Shift + 7: Rotate Viewport to Normals flipping upside down
  • #17389
    Harris Clook
      Not necessarily a problem, I’m just wondering why it does this.
      @18:17 Jonathan selects a couple faces and hits Shift + 7 to rotate the viewport to the normals.
      Initially I did that, but what I did that was slightly different where that the last selected face was different to the one he had selected (The face with the white outline as opposed the others with orange outlines – I forget the actual terms… ‘primary selected’ maybe?)
      When I hit the hotkeys to rotate the viewport to the normals it flipped it upside down.
      When I changed my selection so the last selected face was the same as Jonathans, it rotated the viewport to rightside up. All is good, I’m carrying on tickety-boo.
      Quick note: I’ve tried other variations, and every last selected face bar the last that Jonathan selects seems to flip it upside down too.
      Why might this specific shape be so special that it doesn’t do a summersault on me when it’s the last selected?
      I know I can rotate the island in the UV editor and carry on sailing, but I’m just wondering what’s happening under the hood.
      I’ll add screenshots for visuals
      This is the special face that when hitting Shift + 7 rotates the viewport like you’d expect
      This different last selected face then flips it upside down
      Same boat, but with a last selected face thats right next to the “special face”
      #83632
      Harris Clook
        Edit: Upon following the video, I realise that when shift + 7ing the other eyes/brows etc that the viewport starts doing cartwheels.
        I figure this is normal. I suppose I’m wondering why an isolated group of selected faces, where different last selected face within the group can result in different rotated viewport normals. And to confirm, does shift+7ing multiple faces rotate the viewport to the average normals across each of them?
        #83633
          HI Harris,
          SHIFT+Numpad 7, puts the View, so that the Normal of the Active (the lighter one) Face, points towards you. (So, not the Average Normal of Selected Faces!)
          Now, that still leaves a 360° of possible orientations. If you set the Transform Orientation to Normal, and Select only one Face, you can see the (tangential) X- and Y- axes from that Face, SHIFT+Numpad 7, will turn the Active Face, so that the (positive) Y is up and the (positive) X points to the right:
          #83634
          Harris Clook
            You pinned the tail on the donkey!
            Cheers!
            #83635
              One extra tip:
              after SHIFT=Numpad 7, you can ‘rotate’ the View with SHIFT+Numpad 4 and SHIFT+Numpad  6 (keeping the Face’s Normal pointed towards you).
            • The topic ‘Shift + 7: Rotate Viewport to Normals flipping upside down’ is closed to new replies.
