What are the functions of those? and when you decide to use it? I saw in this video sometimes you activate the Clamp and sometimes not. I checked on video about bevel modifier and I could not find the answer.
Hey @teukuauliar , sometimes I disable clamp if I need a wider bevel and the overlapping areas are not too messy or are not causing any problems – otherwise I leave it on. Hope that helps!
Author
The topic ‘Sharp Edges and Clamp Overlap’ is closed to new replies.
