Select linked Object Data isn’t working.
Forum Archive Select linked Object Data isn’t working.
  • #11219
    frostheart10
      My linked objects aren’t being selected for some reason my Meshe’s have the “fake user” shield where there should be a number next to show how many objects are linked to the object data. Is there a way to fix this?
      #52737
        Sounds like they are not linked. Select all the objects that need to be linked. The one with the orange outline will be the one that the others will be linked to. Press CTRL+L  and in the dropdown Make Links > Object Data.
        It doesn’t matter if you’ve already done that, it didn’t work, or you undid it or whatever; do it (again).
        #52738
        frostheart10
          Thanks I’ll be sure to do this! Thank you so much for taking your time to answer.
        • The topic ‘Select linked Object Data isn’t working.’ is closed to new replies.
