Select an object in blender
Forum Archive Select an object in blender
Viewing 12 posts - 1 through 12 (of 12 total)
  • #9699
    Loopylou Sugarplum
      This is a really basic question however Im struggling with it. How do I select something in blender? I would have thought clicking on it would have done it but no….. seems not! This is so complicated to learn. Can anyone help? Stumbling at the fist block here  🙁 thanks
      #36609
      William Miller
        You use the right mouse button to select by default.  (That will change in Blender 2.8.)  You should watch the Blender Basics course to learn more.  (You can change the selection mouse in the user preferences.)
        #36610
        plasmavoyage
          //edit
          Start with the basics course that William posted, it’s completely free and will get you started in Blender.
          #36611
          William Miller
            @elensanima I don’t get it; they’re the same.
            #36612
            Bauke Post
              @williamatics In Blender 2.8 rmb will still be the default. However, you will probably be able to choose an “industry standard” keymap with lmb.
              #36613
              William Miller
                @baukepost The latest experimental version uses the left mouse button for selecting.
                #36614
                Bauke Post
                  @williamatics I didn’t know that (I haven’t really tested a lot with 2.8), but I came across this on Twitter:
                  #36615
                  William Miller
                    Is Q to select, W to translate, E to rotate, and R to scale seriously industry standard?  That’s ridiculous!
                    #36616
                    Zach Zellman
                      @williamatics that’s how Maya is. I thought it was weird at first too, but it’s kind of like PC gaming. It’s the 4 keys above where your left fingers sit on a key board. That way if you are a traditional typer you don’t have to really move your hand. You don’t really have to move your hand with Blenders hot keys either, but I think in Maya or other apps the Blender hotkeys are used for other tools. Like setting a keyframe is “S” so instead of using S to scale or having to push alt, shift, or ctrl S to scale, they just put it on a different letter.
                      #36617
                      plasmavoyage
                        @williamatics Oh, weird. It shows different titles and preview images for me so I thought the course you posted was the one that talks about how to model with modifiers etc.
                        Sorry about that.
                        #36618
                        William Miller
                          I don’t get why people have such a hard time selecting things in Blender.  The first time I opened Blender, I left clicked.  Seeing that it didn’t work, I right clicked.  It worked!  Then, I saw the manipulator and guessed that it was used to move things.  I moved the cube and went off to find a tutorial.
                          #36619
                          Mark Smith
                            @williamatics if you consider that on the keyboard they are the top row of letters from left to right it makes better sense (QWER)…
                          • The topic ‘Select an object in blender’ is closed to new replies.
