Sculpting, Retopology, Character Modeling, Rigging and Animating.
Forum Archive Sculpting, Retopology, Character Modeling, Rigging and Animating.
  • #14104
    David Soares
      As entitled, this is finally the chosen path I will follow in Blender.
      Most courses and flows are very up to date.
      For sculpting I Did Melvin and the Shark, but what learning flow is recommended specifically for character modeling?? Doing the Introducting Courses.
      #69251
      Adrian Bellworthy
        Hi @donsoarese ,
        Looks like you have a plan, and a lot of work ahead.
        For character modeling  there is Modeling Realistic Character with Blender . It uses an older version of Blender, but if you follow your plan get to grips with sculpting, the different UI shouldn’t be too much of a challenge. The principle of character modeling still applies.
        Good luck on your of creation journey.
        Look forward to you sharing your progress.
        #69252
        David Soares
          Thank you @adrian2301 ,
          having a good plan is often the good way to success. And working hard also.
          Modeling Realistic Character with Blender will be key. I am doing the prerequisite courses as recommended.
          Greetings!
        • The topic ‘Sculpting, Retopology, Character Modeling, Rigging and Animating.’ is closed to new replies.
