Sculpting Help
Forum Archive Sculpting Help
  • #20254
    Niral Damania
      Hello, can anyone help me with a sculpting problem I’m facing?
      So I was trying to sculpt the Shark from the Fundamental’s course and I seemed find it difficult to make the mouth of it. I tried to cut the mouth shape with the Lasso Trim tool but I see these line coming out of the mouth which seems weird and I’mm not able to work on it.
      https://drive.google.com/file/d/1-Q_pRuC71Uezr9VqHPtjXlVdDCKeQu8k/view?usp=sharing
      #95242
        Hi @Niral ,
        I am not sure, but my guess would be, that that is because of the X-Symmetry. Try disabling that when using the Lasso Trim. You can re-enable it after the cut.
        #95243
          Also keep in mind, tools misbehave a lot of the time, it’s just that meshes are unpredictable like that. A lot of time you try it again and it works. Other times you go into edit mode and just clean things up, delete the excess, massage vertices here and there. You can also move your too to do the effecting slightly up or down and it just works, because it might be running straight into a vertex and can be causing issues. Other times you can just use a different tool that accomplishes the same task, just in a different way. But all that to say that these types of errors are common and you just have to do a work around, no matter the software, it happens in Blender in 3D Max in Maya, etc.
        • The topic ‘Sculpting Help’ is closed to new replies.
