Rotating lid planks about their own origin using align view top technique not working (~11:03 in vid)
Forum Archive Rotating lid planks about their own origin using align view top technique not working (~11:03 in vid)
  • #13308
    curtisdd1
      Hi,  I can’t get the lid planks to rotate properly about their own origin  using the select one of the plank faces & align to view -top technique (starting about 11:03 in the vid.  I went ahead and mirrored all but the top 2 planks & modeled the cracks & bumps/scrapes on those so I could continue with the course, but I am hoping someone can shed some light on what i’ve done for learning purposes.  Thanks!
      Here’s my file before i started mirroring or rotating.
      https://drive.google.com/file/d/1Q0pjWI_aP1MbMKaafDfF3ztFM5a0XAma/view?usp=sharing
      #62359
        Works almost like a charm, the only thing is that your Normals of all the planks are flipped, so you need to align view to bottom of the selected Face:
        Or even better: fix the Normals first.
        Select all with A in Object Mode. Switch to Edit Mode and press SHIFT+N. Then All your Normals are correct (facing ‘outwards’)
        #62360
        curtisdd1
          THANKS!!  I couldn’t get it to work right even after adjusting the normals so I’m gonna recreate the chest like i talked about in the other question , apply the damage to the new chest and try the techniques again.
          #62361
            Strange that you couldn’t get it to work. Maybe try the technique on the default Cube first.
            There is also an alternative way, not better, but more general.. Not changing the view, but the orientation.
            On a randomly rotated Object in Edit Mode select a Face (in this case. You can also select an Edge…) and go to Transform Orientations:
            Click the plus:
            Now, in Object Mode you can simply rotate around the Z-axis (in the case of the lid planks by 180°):
            It’s good to know several ways, then you can decide which you prefer (also depends on the situation of course).
            Good luck!
            #62362
            curtisdd1
              THANKS! 🙂    I’m working on building a new chest (i’ve moved the worn/damaged one out of the way)  as well as experiment/work on your technique!
            • The topic ‘Rotating lid planks about their own origin using align view top technique not working (~11:03 in vid)’ is closed to new replies.
