Rings are not rendered in render windor
Forum Archive Rings are not rendered in render windor
  • #20069
    Nicholas Gri
      Hey, thanks for the course, I’m stuck a bit with the rings, they are rendered fine in my blender viewport, but when I try to do render through the render->render image, they are gone….
      Any Ideas?
      #94583
        Check the render camera icon in the Outliner, it may be turned off.
        #94584
          HI Nicholas @NicholasGri ,
          We’ve had this same problem once before, but I can’t remember if we were able to solve it or not…(might be a Compositor thing…).
          Could you please provide a link to your .blend file (via Dropbox, GoogleDrive, or so), so we can see what’s happening here?
          #94585
          Nicholas Gri
            Hi Omar,
            I double checked, and the render option is on for all elements.
            Martin,
            I’ve uploaded the blend file to Google Drive
            https://drive.google.com/file/d/1PLnT5R63ENosyjqtXaJ4aoXMZ2iIiwyG/view?usp=sharing
            One weird thing I’ve noticed today, when I reopened the file, is that the ring was also not rendered in the viewport.
            I fixed that by going to the data section of the ring, and re-selecting the curve (even though it IS selected, just like in the picture). I’ve just clicked on it, and selected again, and the ring appeared.
             I’m on 4.1.1 version  BTW
            #94586
              Thanks for the file!
              Select the RingCircle and go to Object > Convert > Mesh. That should do the trick.
              #94587
                There is an alternative method (so you can Render it as a Curve):
                #94588
                Nicholas Gri
                  Hi @Martin Bergwerf,
                  Thank you for the replies. I’ve tried both approaches, and it worked like a charm!
                  For those who are new, like me, if you want to go with the second option, it should be done in edit mode, then you need to select all 4 points on the ring, and the transform panel will display the Mean Tilt
                • The topic ‘Rings are not rendered in render windor’ is closed to new replies.
