rendering and compositing- cryptomatte
Forum Archive rendering and compositing- cryptomatte
  • #20673
    Moon Cho
      The cryptomatte node that appears at 11:29 in the rendering and compositing is
      different from the one at 22:00. Am I missing something?
      https://www.dropbox.com/transfer/AAAAAGEhLh0I-2Vz-lItleoVBbM41pryUtYv3wkCLQxelZr5WkJnRVk
      #96787
        True, you’re not missing something, those extra Cyptomatte Nodes must have been added off-screen, maybe it got lost in the editing process…
        The question is, does this cause you any trouble? Can you no longer continue with the Course, or is it clear how to Add them nad set them up?
        #96788
        Moon Cho
          Thanks for the response.
          I’ve tried to figure out Cryptomatte and just finished the course. However, I think  It didn’t work. 😅
          How can I fix this problem?
          https://www.dropbox.com/scl/fi/b3wkrqilm5mfhtqnn49ns/IMG_4741.png?rlkey=k5454um81w0ky1mk9toq5p1mv&st=0kweuju4&dl=0
          #96789
            Hopefully someone else that did this course knows it, otherwise, you’lll have to be a bit patient: I’ll probably need to do the whole Course to be able to figure this out.
            But I will get back to you as soon as possible.
            #96790
            Moon Cho
               I’ll also take time to figure out how to solve it.
              No need to hurry. Thanks a lot.
              Have a good day.
              #96791
                Hi @Moon8 ,
                I also finished the course now.
                You seemed to have the Cryptomattes working correctly. I actually don’t know what it is, that is not correct in your image; could you elaborate, please?
                If it’s the human, that is supposed to be visible in that Frame, that might be simply a matter of the order of the Layers.
                #96792
                Moon Cho
                  Hi! Martin,
                  I didn’t fully understand the edited(?) part on Cryptomattes since I’m new to VFX and Cryptomattes.
                  I did some searching and managed to solve it, but I wasn’t sure my solution was correct.
                  If it looks okay, it seems like Cryptomattes worked correctly. Thanks for your help.
                  Have a good day.
                • The topic ‘rendering and compositing- cryptomatte’ is closed to new replies.
