Render problems
Forum Archive Render problems
Viewing 15 posts - 1 through 15 (of 16 total)
  • #11539
    Fabio Tessitore
      Frame 70
      Frame 121
      In my viewport is all ok. Also, I noticed that this kind of things do not happen when I remove the plane
      Any ideas?
      Thanks
      #55217
      shan jay
        Ok this make me confused this shouldn’t look like this
        #55218
        Fabio Tessitore
          Update: the problem is not the plane, but the smoke emitter. If I disable the render of the smoke, it works
          #55219
          shan jay
            huh this must be a glitch. try this
            #55220
            Fabio Tessitore
              Update: the number of particles is too big, with less particle it works
              #55221
              shan jay
                (the number of particles is too big, with less particle it works)
                Well I think this should be not a thing but it is.
                How many particles does it need in order to work ?
                maybe your computer rendering system is not very good
                #55222
                shan jay
                  ops the bullet was a mistake
                  #55223
                  Fabio Tessitore
                    My computer has an i7-8750H, 16G RAM, NVIDIA GTX 1050 4G
                    With 5000 particles works. With 7000 breaks. Same result with more than one emitter, the total must be not greater than 5000
                    #55224
                    Fabio Tessitore
                      Update: Disabling Motion Blur (Render Properties -> Motion Blur) I’am able to render 3 smoke emitter with 5000 particle each
                      #55225
                      shan jay
                        Can you send me the  blend file
                        #55226
                        Fabio Tessitore
                          Google Drive link
                          see frame 188
                          and thanks!
                          #55227
                            Hey Fabio, can you see if this works for you (it renders fine now on my pc…):
                            https://drive.google.com/open?id=1JrSws4NRLMj5BpcomNl3LA_3h5w3N4zO
                            #55228
                            Fabio Tessitore
                              Hi, it works. Please, tell me what have you changed
                              #55229
                                O.k., first of all, you didn’t do anything wrong, it’s a bug. I think it has already been reported (at least an other bug that is probably the same issue). I don’t know what is causing it, but I’m guessing that somewhere in the calculations of the Motion Blur, there is a division by the size or scale of the objects in the scene. When there are objects with size 0, that yields infinity and computers don’t like that and start misbehaving;)
                                You used a Colorramp in the Texture to control the Size of the Particles. The Colorramp had a black flag, and black means 0.
                                Being a genius, I changed the Value of the black color from 0 to 0.0001.
                                That is all! No more dividing by 0 and therefor no more infinity! Computer happy, we happy.
                                Took me quite some time to figure it out though, so maybe I’m not that much of a genius after all…:(
                                #55230
                                Fabio Tessitore
                                  OK, thank you very much. I’ll never use zeros 🙂
                                • The topic ‘Render problems’ is closed to new replies.
