Remove Doubles in 2.80.70
Forum Archive Remove Doubles in 2.80.70
Viewing 10 posts - 1 through 10 (of 10 total)
  • #10379
    Kornei Sgibnev
      Hello everyone! Yesterday I downloaded the latest version of blender 2.80.70 and I can’t find the option that removes double vertices. Does anyone know where is it now?
      #46629
      smurfmier1985
        You have to be in Vertex select mode (it won’t work with edge and face select). I believe it’s in the menu you get when hitting the ‘W’ hotkey.
        #46630
        odunov
          It’s under the merge vertices menu now. Press alt+m (or ctrl+v > “Merge Vertices”) and select “By Distance”
          #46631
          smurfmier1985
            @drgnclw ha! learned something today 🙂
            #46632
            Kornei Sgibnev
              @drgnclw Thank you very much! Don’t know if I’m happy with the choice they made…
              #46633
              Robin Hammond
                @korneisgibnev098  Hi to remove doubles . Be in edit mode press ctrl v almost at bottom of menu displayed is remove doubles . A box appears at bottom left of screen where you can adjust distance of vertices.
                #46634
                numbernine
                  @korneisgibnev098 I think the new name makes more sense, but I did like its old position in the right-click menu. Now you need to go to a submenu afaik, which is a bit slower.
                  #46635
                  smurfmier1985
                    @numbernine you can always add it to your quick favorites
                    #46636
                    numbernine
                      @smurfmier1985 True, but I’ve lost my quick favourites numerous times now when I go to grab a new daily build. I’m not sure how to save them permanently. I tried saving preferences / saving startup file but it didn’t always carry over. I’ll use it more after the full release.
                      #46637
                      Jake Korosi
                        @numbernine Yeah same with me – unless I’m playing with a specific new feature, I tend to just keep by 2.8 builds on “factory” settings and won’t mess around with themes, making Q menus, or customizing settings and layouts until it’s official.  Word is, there’s only a couple of months to go…
                        I also haven’t been a fan of every decision the dev team has made.  Still, I’ve been able to adapt to pretty much all the changes relatively quickly as they come.
                      • The topic ‘Remove Doubles in 2.80.70’ is closed to new replies.
