Questions about white spots on model in edit mode, subsurf on with display in edit mode on
Forum Archive Questions about white spots on model in edit mode, subsurf on with display in edit mode on
  • #11612
    curtisdd1
      Hi, I am seeing white spots in model with subsurf on and display in edit mode on and wondering if those are areas of problems  that need to be fixed like vertices too far in or out?
      #55492
        Don’t worry, that is completely normal. It is because it shows the wireframe un-subdivided and the mesh subdivided. Where the wireframe goes below the mesh you get these ‘white splodges’;)
        If you want you can ‘hit the triangle’ like this:
        #55493
        curtisdd1
          THANKS! 🙂
        • The topic ‘Questions about white spots on model in edit mode, subsurf on with display in edit mode on’ is closed to new replies.
