[Question] tank chains
Forum Archive [Question] tank chains
  • #9719
    Macario Lopez
      Hello,
       I am trying to animate the chains of a tank. I have made a simple chain part and applied a bevel modifier, then an array, a curve modifier and assigned them to a nurb-circle which I have modified to fit my tank. Both the circle and part (As far as I know) has been created at the origin. I also tried to place the origin at the center of the volume and at the center of the surface for both the chain part and the nurb-circle.
      Everything went as I would have expected it. So I proceeded with my experiment.
      I then wanted to animate (and later rig all relevant part to facilitate the animation of my tank),
      so I applied a < follow path > constraint to the chain part to automatically animate it. There is an undesired effect.
      Please take a look at this effect in the file I have attached.
      I really would like any feedback.
      Thank you in advance.
      #36738
      Char Hunter
        Macario,
        I’m not much at rigging and animation,  But I see something odd on your timeline at 5 seconds in the video.  Looks like jagged lines, then they straighten out.   Could you have keyed something offset movements there?
        Char
        #36739
        killer-wolf
          assuming you mean “track” and not “chains”, if you check on youtube there used to be a good tutorial by, iirc, Chris Kuhn, on how to rig/animate this.
          #36740
          Thibaut Bourbon
            @mac999 I think @killer-wolf is referring to this course:
            https://www.cgcookie.com/course/rigging-tank-treads
            Maybe you are actually already following it and struggling with a specific part of it ?
            #36741
            killer-wolf
              @tbrbn
              that’s the one, i thought it was a youtube thing.  anything by Chris is top notch.
              cheers
              #36742
              Macario Lopez
                Thank you to everybody.
                I will take a look at it:)
              • The topic ‘[Question] tank chains’ is closed to new replies.
