Question about parenting and join
Forum Archive Question about parenting and join
  • #14872
    you
      use Ctrl + P to parenting
      use Ctrl + L to joining
      it seems like that joining will inherit transformation as well as texture ,whereas parenting only inherit transformation
      just wondering what’s the main difference between these two ? and is there any thing that i should pay attention to ?
      Thank you
      #73458
        The hotkey for joning is: CTRL+J!
        This makes two or more Objects into one. It will take the Name and Modifiers of the Active Object and keeps the colors as they are.
        Joining these two Objects:
        will give:
        But changing the Active Object to be the Plane:
        will result in:
        When Parenting, you will keep the seperate Objects, but when you Transform the Parent, the Child(ren) Transform(s) along.
      • The topic ‘Question about parenting and join’ is closed to new replies.
