Query re adding creases to clean up the subdivided copy of the door frame low
Forum Archive Query re adding creases to clean up the subdivided copy of the door frame low
  • #8294
    Michael Richards
      After creating a copy of the door frame low, and adding a displacement modifier and a subdivision surface, you added creases to nearly all edges. This includes all the edges added previously when triangulating.
      Rather than adding creases to nearly all the edges, would it perhaps work better if you first Select Sharp Edges, and then only add the crease to those?
      I tried this, and  I needed to add a couple of extra creases in lines leading to concave corners, but overall it seemed to work ok. Just wondering if I am missing something.
      #28477
      Jonathan Lampel
        It doesn’t sound like you’re missing anything, that’s a totally valid way to do it! It’s even the preferred way if you have any areas that need to remain smooth.
      • The topic ‘Query re adding creases to clean up the subdivided copy of the door frame low’ is closed to new replies.
