Excellent, glad you got the first part figured out!
For the second one, that will happen if the low poly mesh is inside the high poly mesh instead of the other way around. A good way to fix this would be to use the cage object (I see it’s not assigned in the screenshot).
Baking normals can definitely be confusing at first, so keep it up! Soon it’ll be second nature.
