Principal object, bigger than the geometry nodes system
Forum Archive Principal object, bigger than the geometry nodes system
  • #21418
    Hillerl. Lozano
      Hi, at the moment everything is working fine, but i don´t know why the original pad object is much bigger than the geometry node system, why this is hapenning?
      #99781
      Hillerl. Lozano
        I found the answer, is the value that i give to the GN system, when i modify the “GAP ” value is gona change de dimensions of the pad
      • The topic ‘Principal object, bigger than the geometry nodes system’ is closed to new replies.
