Ok, I discovered something today (and I’m quite new to rendering in Blender).
I have rendered a long animation to EXR files, but then I made some small adjustments at the end and wanted to create a ‘playblast’, but it used the same output folder and file format, so it overwrites the EXR files I have rendered (which took several hours).
Shouldn’t there be a separate output folder/file setting for playblasts? I don’t typically want EXR for playblasts, but changing output settings is easy to forget.
There is an option to not overwrite files, but what does it do if you create a long cycles render? Does it give a warning or does it render (for hours) without saving? Do you have any experience or tips?
Is there any way to handle this better, built in workflows, or addons?
