Pinning a bone constraint properties tab per bone
Forum Archive Pinning a bone constraint properties tab per bone
  • #18732
    Harris Clook
      Just following along at the mo’. Is it possible to pin the constraint tab for the Owner bone to stay open when I select the Target bone? Ie. If I want to swap between the different locked track constrain options to try test them out and move the target bone around I don’t need to reselect the owner bone each time?
      There is the pin icon at the top right of the properties tab which I enable for the owner bone, but it changes to the target bones constraints tab when I change my selection.
      This might not be necessary, but at the moment it seems like it would speed workflow up?
      #89347
      Wayne Dixon
        Hey Harris,
        That pin icon only works the way you are expecting when you select a different object.
        If you select a different bone, then it will show you the constraints for that bone.
        One thing you can do is right click in the target of the constraint and “jump to target”.  This will select the target.  But I’m not aware of any way of jumping back to the owner without manually selecting it I’m afraid.
        Hope that helps.
        #89348
        Harris Clook
          Not a problem! Just something to get used to! Cheers!
        • The topic ‘Pinning a bone constraint properties tab per bone’ is closed to new replies.
