Opened my saved blend file after the last tutorial, and there was no backdrop image. Re-selected the source file in one of…
Forum Archive Opened my saved blend file after the last tutorial, and there was no backdrop image. Re-selected the source file in one of…
  • #5075
    Matthew Runkle
      Opened my saved blend file after the last tutorial, and there was no backdrop image. Re-selected the source file in one of the Image nodes, and it appeared except that most of the image is missing. Only a small rectangle along the bottom is visible. Changing the Draw Channel to Color shows most of the image as black. The Combined, Alpha, and Depth outputs of each of the three image nodes are all confined to this same small area. Grateful for any help!
      #23420
      Matthew Runkle
        Solution: on the Viewport Properties Panel under Performance I had Viewer Border checked. Apparently, when I box selected my Orb_Diffuse nodes to create the Node Group the box select was at the same time creating a Viewer restriction that became apparent after saving and re-opening the file.
        #23421
          Thanks for posting your solution! I was scratching my head trying to figure out what that could be.
        • The topic ‘Opened my saved blend file after the last tutorial, and there was no backdrop image. Re-selected the source file in one of…’ is closed to new replies.
