Only one vertex group on the list
Forum Archive Only one vertex group on the list
  • #13526
    loneranger1218
      When I parent my gun mesh with Armature, in the vertex group I only see root vertex group. There is no other ones.
      If I add them manually, they don’t move my geometry.
      #63032
      Jonathan Lampel
        Interesting, when you parented the rifle to the armature did you choose Armature Deform With Empty Groups? That’s what will create a group for each of the bones in the rig.
        #63033
        loneranger1218
          I’m using my own mesh and did it exactly like you show on video. When I add groups manually and assign to parts of my mesh, they don’t move it. Only root bone works.
          #63034
          Jonathan Lampel
            Can you share your file via dropbox or something?
            #63035
            loneranger1218
              Rig is in separate collection which should be active.
              #63036
              Jonathan Lampel
                Oh I see! It’s because the armature modifier takes one armature as an input while all of your bones are separate armatures. Quick fix is to select all your armatures, make the root the active object, and press Ctrl+J to join.
                For more about working with armatures and bones, I would definitely recommend Wayne’s new rigging course:
                https://cgcookie.com/course/fundamentals-of-rigging-in-blender-course
                Hope that helps!
                #63037
                loneranger1218
                  Yes, it’s working! Thank you for help and quick answer 😉
                • The topic ‘Only one vertex group on the list’ is closed to new replies.
