One of the first steps to the video is to tab into edit mode / open the uv editor. When I opened the project file provided…
Forum Archive One of the first steps to the video is to tab into edit mode / open the uv editor. When I opened the project file provided…
  • #4390
    Nick Bell
      One of the first steps to the video is to tab into edit mode / open the uv editor. When I opened the project file provided it does not allow for me to go into any mode at all. When I click on to manually switch nothing is listed but the current mode it is in “object mode”.
      I have tried re opening the file a few times and the same thing every time. Is there a option turned on that would stop me from switching modes?
      Thanks
      #22441
      Danny H
        I actually got confused by this for a moment too. When you open the project file the object isn’t selected yet (note the lack of a yellow highlight around it).
        Once you select the object you’re able to tab into edit mode.
        #22442
        Nick Bell
          Thank you for the help!
          I had hit a key to select. It had the object highlighted still wouldn’t let me switch to edit mode. I De-selected and re-selected the object and then I was able to change to edit mode.
          Where hitting a because it is a “select all” option. Does that stop you from changing to a different mode?
        • The topic ‘One of the first steps to the video is to tab into edit mode / open the uv editor. When I opened the project file provided…’ is closed to new replies.
