On the normal map baking example, when I change the shading mode to GLSL and the viewport shading to Texture, the model do…
Forum Archive On the normal map baking example, when I change the shading mode to GLSL and the viewport shading to Texture, the model do…
  • #4442
    striderxz
      On the normal map baking example, when I change the shading mode to GLSL and the viewport shading to Texture, the model does not illuminate properly. This happens in Object Mode (for some reason edit mode seems to be applying the normal map correctly). Is there any setting I may have skipped? Here’s a screenshot for reference http://tinyurl.com/zfquoln
      #22542
        Hmm..it looks like your mesh’s face normals are reversed. Try selecting all faces in Edit mode and “Flip Direction” in the Shading/UVs tab of the tool panel.
      • The topic ‘On the normal map baking example, when I change the shading mode to GLSL and the viewport shading to Texture, the model do…’ is closed to new replies.
