On the joystick, the splines seem a bit awkward. A couple of spins seem to look nice, although tricky to do. Would they be…
Forum Archive On the joystick, the splines seem a bit awkward. A couple of spins seem to look nice, although tricky to do. Would they be…
  • #4906
    Kevin Mather
      On the joystick, the splines seem a bit awkward. A couple of spins seem to look nice, although tricky to do. Would they be preferred?
      #23208
      Stanley Leland
        As Mr. Williamson says it isn’t clear what you are referring to. If you are talking about a change in the mesh that doesn’t effect the render than the fewer polygons needed the better. If it effects the render than choose the look you like the best. 😉
        #23209
        Kevin Mather
          Obviously I should have typed “shear” not “spline”. I had never seen it used before. I can get a “bent pipe” with shear+shear (less geometry) or spin+spin (smoother). If it is just personal preference, fine. I thought that there might be some side effects (unknown to me) that would make one more desirable. Thanks.
          #23210
          Stanley Leland
            Shear produces more of a mitered joint and may be simpler for a beginner than Spin. Blender has many ways to do the same thing. Once applied the topology is just topology. So I would say it is personal preference.
          • The topic ‘On the joystick, the splines seem a bit awkward. A couple of spins seem to look nice, although tricky to do. Would they be…’ is closed to new replies.
