On Mesh Modeling Exercise 1, I have loop cut the cube to make the 90 degree cutouts on the corners. However, when I make …
Forum Archive On Mesh Modeling Exercise 1, I have loop cut the cube to make the 90 degree cutouts on the corners. However, when I make …
  • #3924
    Michael Prostka
      On Mesh Modeling Exercise 1, I have loop cut the cube to make the 90 degree cutouts on the corners. However, when I make the new back faces, Blender wont dissolve them into the original faces. Is this ok? From the example shown I cant tell if this is acceptable geometry.
      #21859
      Stanley Leland
        You are not required to follow the examples. Best way to do the corner insets of the cube is to select all the faces and use the inset tool with the cntrl key constraint.
        Here is a thread showing one way to do the corners.
        http://community.cgcookie.com/t/help-needed-on-the-mesh-fundamental-exercise/2370
        #21860
        Michael Prostka
          Thank you! That works a lot better than the direction I was trying to go!
        • The topic ‘On Mesh Modeling Exercise 1, I have loop cut the cube to make the 90 degree cutouts on the corners. However, when I make …’ is closed to new replies.
