Not sure about what you’re doing around 7:20
Forum Archive Not sure about what you’re doing around 7:20
  • #7859
    giovanni2
      What is that second copy of the retopologized object? Why are we copying the “combined” version of the UVs to it?
      #27751
        I’m simply “transferring UV maps” from one object with UVs to a duplicate of the object (same mesh) without UVs. I duplicated the entire stack of rocks to layout UVs together into a consolidated map because in order to lay out all their UVs together they need to be combined as one object. I want a consolidated UV map so all the individual rocks can share a single texture.
        I left the original stack of separate rocks so I could separate the duplicate stack of UV’d rocks and transfer UVs from each individual duplicate rock to it’s counterpart.
      • The topic ‘Not sure about what you’re doing around 7:20’ is closed to new replies.
