node framing
Forum Archive node framing
  • #17631
    Csüllög György
      9:03 hit shift key?  sorry i dont understand that part what do i need to press to frame it up?
      #84666
        Inside the node editor you can add a frame with Shift + A, it’s just a way to keep things more organized.
        #84667
        Csüllög György
          ah thank you thats it but how does he adds it automatically?  so i dont need to play with the sizes?
          #84668
            And if you have the Node Wrangler Addon enabled, you can use the hotkey SHIFT+P to Frame Selected.
            #84669
            Csüllög György
              ah  super thats it . Thanks , both of you.
              #84670
              Dwayne Savage
                It’s Ctrl+J to frame selected. If you have node wrangler addon turned on then you can also use Shift+P, which a lot of people prefer since alt+p removes selected nodes from the frame.
              • The topic ‘node framing’ is closed to new replies.
