Forum Archive › No change in the compositer
Hi, got to the composite stage but it doesn’t change anything. I’ve tried multiple nodes but it doesn’t change the render / image? any ideas please?
thanks
https://imgur.com/a/vdcjAHo
You need to connect the fogglow. To the viewer node as well so that you can see the effect of the node. Also try a mix of less than 0.99 because 1 will always be black unless you add emission.
Yes, same, adjust the mix value and connect the node to the viewer node in order for the previz to work.
And Yes, same. Notice the fog glow mix in the course is 0.00
