Need help on Latch
Forum Archive Need help on Latch
  • #21195
    HENRY DUGAN
      At 17 minutes 30 seconds I am stuck.  I am trying to pull the single edge on the y axis but it just seems to be grabbbing the vertex next to it.  I don’t want to start over.  I selected the 3 faces for the latch and duplicated them.  It shows up in my collection.  I have latch selected and try to lengthen the latch but won’t work.  Is there a way to include screenshots of my project?  Thanks Jim
      #98890
      Jaanus Väinsalu
        maybe magnet is on, and yee you can answer this post and add pictures with a picture icon in the top bar of answer tab, just upload them and then add
        #98891
          Remember though, starting over is essential, it is always a great choice to start over. When a mesh is a mess, cleaning it or trying to get the loops to flow another way or cleaning it or breaking stuff apart to redo, it’s always a waste of time and starting over is the best choice, not only is it faster but you learn a lot more, you learn of ways to not go about a mesh, you gain speed, etc.
          As Jaanus says, most likely snapping is on.
          #98892
          Charles
            You don’t have to use the WYSIWYG buttons to insert an image. You can just copy paste images into the body of your message.
            #98893
              Or maybe it’s not Snapping, but Proportional Editing (shortcut O), that’s on.Or both, hard to tell from your description alone.
            • The topic ‘Need help on Latch’ is closed to new replies.
