Hi Monica, I am not sure, but it looks like the problem lies within the UV Map…
Did you unwrap the sphere like it was shown in the video?
The modern-day UV-Sphere comes with an unwrap by default, but that is completely different from unwrapping it manually…
The only strange thing in your Node Tree is, that you plug the Texture Coordinates (in your case UV) into the Location of the Mapping Node, instead of in the Vector socket of the Mapping Node, but that is not what is causing your issue.
(And you don’t need to connect the Z through a Clamp Node, because UV’s do not have a Z component…)
If unwrapping doesn’t help, please provide us with a link to your .blend file (through Dropbox, GoogleDrive, or so), so we can troubleshoot 🙂
