my render animation isn’t rendering anything. I have followed everything to a tee, but i just get a blank page.,but i can render a picture.
Forum Archive my render animation isn’t rendering anything. I have followed everything to a tee, but i just get a blank page.,but i can render a picture.
Viewing 15 posts - 1 through 15 (of 15 total)
  • #14328
    titus gore
      #70361
      Sébastien Lenaerts
        Hey, can you post screen shots ? (Scene settings, composition)
        If you delete or didn’t select a camera your render would be black, yours is white, maybe you used a mix node in composition tab mixing your image to white and missed a connection?
        Or maybe you accidentally hid the folder of your objects for your render?
        Or your camera is outside a universe object you use, but then you shouldn’t be able to render an image either
        #70362
        titus gore
          titus gore
            titus gore
              titus gore
                titus gore
                  the output i get is a black background with the grids, the camera is pointing to the model
                  #70367
                  Sébastien Lenaerts
                    @titogore , I can’t see any light source in your collections (maybe hidden) , if it is all black, then probably this might be a problem.
                    The fact you see the grid lines hints me that this could be the case.  Can you confirm?
                    #70368
                    titus gore
                      i have a light source, its in the rockest asset
                      #70369
                      titus gore
                        though i do not check that box , but i duplicated the light with the rocket and camera when attaching the fins of the rocket stage, and i did not mention when i begun the project they said delete everything but i did not delete the cam and light!! at the very beginning
                        #70370
                        titus gore
                          i found the error, now rendering thanks
                          #70371
                          titus gore
                            my camera dimensions….the error it said not divisible by 2!
                            so i used preset camera 1080p
                            #70372
                            Sébastien Lenaerts
                              Ah, happy you found the culprit 🙂! Good launch!
                              #70373
                              Adrian Bellworthy
                                Hey @titogore ,
                                You shouldn’t need a light if you added the HDRI. This will illuminate the scene.
                                If you are seeing the grid lines this tells me you are rendering the viewport animation and not the camera render.
                                To render the camera you can use CTRL + F12 for animation or F12 for an image.
                                The ROCKET ASSET collection should be left unchecked.
                                #70374
                                  Thank you! I have never seen this before 😉 It is an external library problem (MPEG4 in this case, but AVI also can’t handle it…)
                                  I haven’t tried all codecs, but OGG can render odd dimensions.
                                • The topic ‘my render animation isn’t rendering anything. I have followed everything to a tee, but i just get a blank page.,but i can render a picture.’ is closed to new replies.
