My Model Override pull-down menu doesn't list any models. The only choice is "None". Any suggestions on how to replicate…
Forum Archive My Model Override pull-down menu doesn't list any models. The only choice is "None". Any suggestions on how to replicate…
  • #5779
    ostuni
      My Model Override pull-down menu doesn’t list any models. The only choice is “None”. Any suggestions on how to replicate what you did in your video?
      #24348
      Jonathan Gonzalez
        Make sure you have SteamVR running before you open Unity. That seems like it caused issues like that for me. If you still have issues you might want to shut down Unity and SteamVR then try it again. I’ve had plenty of times where certain models wouldn’t appear either and Unity would give an error even though it worked previously. The Steam plugin is still a work in progress so expect things like that but in general I find restarting things helps.
        #24349
        ostuni
          Thanks for your reply. My mistake was that I was running the code from your video on my Mac which doesn’t have Steam. When I tried it on my PC it worked fine. I didn’t realize the models were coming from Steam and not the Unity SteamVR plug-in. -John
          #24350
          Jonathan Gonzalez
            Ah yes. I had to use my Windows machine. There has been talk that Steam VR would run on Mac but I have yet to see that happen. It’s a bummer since I do most of my development on the Mac side myself.
          • The topic ‘My Model Override pull-down menu doesn't list any models. The only choice is "None". Any suggestions on how to replicate…’ is closed to new replies.
